Anybody figured this one out yet? 1g rear clickity clack
Black91TSiAWD
1,080
Nov 30, 2004
Binghamton, New York
Ok my new 90's rear drivers side rotor(I know thats what it is, cause I step on the brake and it goes away)is clicking and clacking like crazy as I drive down the road, its so annoying and it drives me nuts. My 91 used to do the same thing and I have no clue what I did to get rid of it, its been a while.
I took the wheel off and started grabbing and shaking everything I could to get it to make the sound but nothing. Oh and its got a broken caliper bolt in it, so I just put the tire back on and said eff it, thats another day.
So I know lots of other people have had this problem, but has anyone came up with a cause and effect/solution for it? I cant stand it and I need to do somethign about it.
Black91TSiAWD said:
Ok my new 90's rear drivers side rotor(I know thats what it is, cause I step on the brake and it goes away)...
Actually, a sound that goes away when you apply the brakes does not have to be brake-related. When the brakes are applied, the brakes also prevent the hub from moving in and out (as much), so it could also be a wheel bearing.
- Jtoby
well I thought that too, but I shook that rear rotor and everything with all I had, youd think if there was any play with the bearing Id have gotten a sample of it at the time.
Im kinda thinking the brake pads are flopping around in there, or something to do with the rotor, pads, or caliper. All of which I cant figure out until I get the bolt out of the caliper :(
Well to check for that, jack that side up till the wheels off the ground. Grab the wheel at 12 o clock and 6 o clock and try to wiggle it. If there's any play the bearing is going. Not something to drive around with.
