Will a 2G GST need a camber kit with the Tokico struts and springs kit?
truwarrior
1,422
6
Dec 19, 2002
Will a 2G GST need a camber kit with the Tokico struts and springs kit? Hows the ride? Any pics? Thanks!
Again, this is a useless thread without more information. For example, if the car is being set up for autocrossing or road-racing, then you not only don't want a front camber kit to delete some negative, but you might want one that will add some more negative, if such is legal under the rules. Conversely, if the car is being set up for drag-racing, then, yes, you might want to take out some of the negative camber you gained in the front. A middle-ground, street car might want the front realigned to near-zero toe and left alone, camber-wise.
In either case (turning or going straight), you will want to space out the rear upper arms, but you knew this from the million of previous threads, so I don't know why I am mentioning it here. Maybe because I like the sounds my fingers make on the keyboard when I type certain, extremely-well-practiced sentences.
clickety click
- Jtoby
