what offset with 19's
How wide is the rim? -40mm should be a perfect fit. Stock is -46mm but because of going with a wider tire you must compensate for the extra width of the tire.
Running 235/235/19 all the way around is gonna be a hell of a good thing with the AWD......... Do you really need anything wider than the 235's all the way around? If not than dont create any headaches for yourself. Stick with the 235's. You couls go wider if need be, but some trimming will need to be done, proper offset will again become a concern, and how low will your car be? Give me a full scenario of what you are looking to acheive with the setup your considering.
