PhoenixRPR
- 450
- Oct 9, 2002
San Diego,
California
I've received my new Axxis metal master brake pads and Brembo cross-drilled/slotted rotors. Before I attempt to install the new brakes, any words of wisdom for a first timer?
Um... you DO have a shop manual, don't you?Originally posted by PhoenixRPR
Why would I be screwing in two bolts to pop them off the hub? I'm confused, I would assume I'd be screwing bolts out to get things off.
Originally posted by jim97gst
You may need a clamp of some kind to push the caliper piston back so you can fit in your new pads. I can usually do it by just pushing on it with a block of wood with both hands.
Good luck!
Don't forget to lube your caliper bolts with the special grease (it's red and comes in a little packet like ketchup).
Keep your bottom and top caliper bolts straight. They are different. They are marked on the ends.
Find some way to support the caliper while you're working on the rotor. Don't let it fall and hang by the brake line.
Good luck!
Originally posted by jtmcinder
I'll answer, but this really should be moved to the newbie's forum.
In theory, once you take the brake caliper off, the rotor can be pulled off by hand. The problem is that theory doesn't take the reality of years of salt and grime into account, so your rotors will undoubtedly be stuck to the hubs. Luckily, Mitsu foresaw this and - like most makers - put two little threaded holes in the rotor for you to screw bolts into. As you screw these bolts in, they press against the hub, leveraging the rotor off. In practice, what happens is that you keep screwing in the two bolts, alternating from one to the other after each quarter turn or so, with it getting harder and harder, until, in a loud bang, the rotor suddenly pops off, scaring the crap out of you.
In about 25% of the cases, when we're talking about rotors that have been on there for a decade, the rotor actually cracks at some point. Be ready for this.
- Jtoby
