smills1840
- 365
- 22
- Nov 8, 2011
Blacksburg,
Virginia
Hey everyone,
Just bought a set of rotors and pads off eBay from this link http://www.ebay.com/itm/400733458061?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I installed everything, and as soon as I rolled it out of my garage I could tell something wasn't right. The brakes almost felt like they were locked up. I immediately put it back up on jack stands and saw the front driver side rotor has a pretty bad scratch all the way around.
I discovered that one of the metal tabs on the pad spring(?) was touching the rotor. I bent it back, but then realized that the caliper was sitting too close to the rotor all together. It wasn't like this on the passenger side. I shimmed the caliper so that everything is centered.
I put everything back together and bled everything in this order: Passenger Rear, Driver Rear, Passenger Front, Driver Front and went up the street slowly. My pedal has always been soft and gone to the floor way too easy, so I figured bleeding would help that. It didn't though. The pedal felt the same as it always has, and the car seemed to stop worse than before.
I decided to bleed the brakes again, this time using a vacuum bleeder pump. I used the same order, and also flushed the brake fluid. However, when I went to test the brakes this time, the pedal pulses badly and when coasting the steering wheel shakes back and forth. I didn't touch the caliper bolts or anything like that. I'm really not sure where to go from here.
Any info would be helpful. Thanks guys!
