2 slim fans with temp sensor and AC - Is this ok?
tunermag
51
8
Apr 12, 2005
Buenos Aires -, South America
Hi, I'm trying to run both slims fans with the thermo switch and same with the AC. I can't find a diagram to do that, so I think in the following solution.
Pls help me to know if it is ok or there is an easy way.
Car is a 1992 GSX with two slim fans.
Original circuit:
My plans: (changes in red)
Wich translates to:
unplug terminal 1 on radiator fan motor (A-03X) relay and plug it into terminal 4 on condenser hi-low relay (A17X)
Wire radiator fan motor positive with condenser fan motor positive
unplug terminal 3 on condenser hi-low relay (A17X) and join terminal 2 and 3 on the same relay
Is this ok? Tks you
PS: Both fans will run on high all time the conditions mets (AC ON or temp switch)
Last attemp on getting insight before going with this mod
    • 92AWDHX40
    • eclipsemf
