street dsm 11/10/9 seconds build venezuela
Boost Solution
Proven Member
50
19
Apr 22, 2013
Venezuela, South America
hi Im fom venezuela this is mi build to 11 , 10 and 9 seconds
9/19/2010 The car was a Eclipse gsx 93 syncro built for a friend by myself with
manley pistons 8.5/1
eagle rods
brian crowe 280
custom degreed
1mm os valves
ebay turbo manifold
garret turbo tuck 60/1 t3.63
tial 38mm
xtd cluch
non eprom stock ecu
1g maf traslator
evo 580 injectors
Methalon 1000cc injection
Precision intercooler
ugly huge no name fuel pump
THE car ran 11.90 with radial and pump gas metha @ 20psi
and a old video
[ame=http://www.youtube.com/watch?v=60rxhKK0Aj8]eduardo turbo 11.95 - YouTube[/ame]
12/21/2010
my friend crashed the car and I'll buy it and started the reparations
the car was repaired and ready to start looking for the 10 and IM THE OWNER:hellyeah:
same engine
precision 6262.63 jb
750 injectors
044 fuel pump
act cluch
new brakes shafts and read end 4bolt
aem lancer ecu
diy conversion harness
24/1 trigger disc
dual syncro second gear
weeld center diff
44tia wastegate
[/IMG]
second gear pull 30psi pump gas metha
blow cluch
blow drivesahft
blow transfer
blow second gear and shift fork
in one month
the answer :ohdamn: I need more power
build top mount manifold vband.82
880cc injectors
rebuild gearbox
custom steel shift fork
cp pistons
kelford big cams
kiggly springs
kings hla
kyb rear shocks
new block custom hone
cooper o-rings
new steel flywheel and cluck disc
http://sphotos-b.ak.fbcdn.net/hphotos-ak-
ash4/431562_10150621754961313_570675753_n.jpg
first start
[ame=http://www.youtube.com/watch?v=fOHoEcWBcEw]Boost Solution Kelford first start - YouTube[/ame]
im go to the dyno and tune to 30psi and make 560whp and 458 torq ultra safe tune on c16
slicks
10.52 second pass cluch slip
[ame=http://www.youtube.com/watch?v=g6fxr-LI9dg]Eclipse Mauro Gallo - YouTube[/ame]
4 pro race
[ame=http://www.youtube.com/watch?v=guHnoW2vA6s]Eclipse Mauro vs Subaru Gocho - YouTube[/ame]
http://www.youtube.com/watchv=OL3BmgOgGyA
[ame=http://www.youtube.com/watch?v=xGY81b4dJq4]Eclipse mauro vs subaru kartec .3GP - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=qTT70Dl7UtY]Ecplise Turbo Vs Suba - YouTube[/ame]
photo.php
http://sphotos-d.ak.fbcdn.net/hphotos-ak-snc7/422354_10150979313526313_791890831_n.jpg
[ame=http://www.youtube.com/watch?v=Asze3kHqteQ]Eclipse Boost Solution 10.42 1.38 - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=m0Y3zg8aNXw]Mitsubishi Eclipse Turbo 10.42 The Valley Drag Way Pica Pica - YouTube[/ame]
new 66mm turbo
cdi ignition
quarter master dual
jmf drag manifold
80mm tb
tune on mustang dyno 30psi max injector duti 620whp
[ame=http://www.youtube.com/watch?v=kxEIArNQYsM]Mitsubishi Eclipse Mauro (9.91 seg) Record nacional "Venezuela" - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=myDsrhjp1sU]Récord nacional 4 PRO Boost Solution Mauro Gallo - YouTube[/ame]
the fast 4 cylinder venezuela car
I disassemble the engine install grp aluminum rods ID2000 injectors, new fire rings, gaskets and camshaft Sprockets. and the results are amazing 801 awhp 40 psi boost only 9800 rpm
[ame=http://www.youtube.com/watch?v=pEQERb_AXrQ]Boost Solution 800hp - YouTube[/ame]
thank you very much
at this time im build the roll cage, I hope go to the track this Saturday
in the past with 2645 lb the car ran
520hp single clutch stock manifold 10.42 6262 30psi
640 hp dual disc jmf drag manifold 9.91 6466 33psi
800hp 40psi :hellyeah:
I want to run 8 with the 6466, the new setup I'm putting together is 6466 t4 twin scroll, custom front mount turbo manifold, twin tial 38mm, 4.5"core 1469 CFM intercooler , 3" short piping, evo 3 first gear, tubular front end, 4 "exhaust, aem ems serie 2,
I know this maybe a dumb question but what cam gears are on your motor?
Never seen them before.
Great build. What do you think of those cam gears? I might just be getting some myself, I had the skunk2 gears, but couldn't get myself to install them because of the reviews. Your car has pushed 800awhp and I'm in the same range or am going to be around that with my gt42 and was wondering what you think of them personally?
Keep up the good work. Love the car and the dedication you have for it.
Anthony B.
Work Cam Gear Sprocket are light and well finished good and had no problems with them.
# I personally think a GT42 is overkill for 800whp, I will use a smaller turbine for better powerband instead of a short peak power
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
