90 mirage awd turbo project
cruzanspeed
Sep 17, 2007
Orlando, Florida
Hi everyone I'm Joey. Well I've always wanted to do a mirage/colt hatch project but never got around to it and there are not that easy to find in Florida. So back in November 2012 I picked this 90 mirage up with an awd swap already in it. It also came with a few other goodies. Will be using the motor from my last 95 eclipse gst that had a built 6 bolt. Transmission from a 93 gsx that I will be rebuilding. The car was set up for drag racing I will be making it a street/drag toy. Will keep posting as things fall into place.
Last setup before I purchased it. Car was originally built by jaytech tuning & fabrication.
That car had to be a beast before. What are the plans for the new engine?
I love the color BTW
Fuuhhh this things was beast...
It was setup to be a beast but he parted it out before he had a chance to start it up.
Parts collected
Built 6 bolt short block with a 7 bolt head.
Holset WH1C T3
Turbonetics T3 manifold
EVO3 intake manifold
AEM V2 EMS
Fuel cell
2 Walbro External fuel pump
Big fmic
Coil & Plug
ect..
The paint is very nice when the sun hits it.
Any idea how the rear end was fabricated in ? I've owned several mirage turbo FWD's but always wanted AWD . The stock beam axle setup is lacking. Was a cyborg floorpan and subframe utilized, or is it tube steel fabricated ? And how the heck does the fuel pump get fuel from both halves of the gas tank ? These are hurdles that kept me from chopping mine up. Please tell me how, so i start another foolish project !! You're going to have fun once that enormous turbo spools !
Using a 1g rear with two 4x2 box beams to support it. You will have to go with a fuel cell with inline fuel pump. Check out 4g61.org. I can't wait to finish :thumb:
Little update on parts purchased
AEM v2 ems
6 blade HX40 & BEP housing
Intercooler & piping
Dual walbro setup
880cc precision injectors
Evo3 intake manifold
Evo3 turbo manifold
Tial 44mm wastegate
cp pistons
eagle rods
acl rod & main bearings
arp head & main studs
Fidenza flywheel
Sold original motor building fresh motor 6 bolt & 7 bolt head with kelford 272
Project is on hold for about 3 more months while I finish my dd. MK3 supra with 1.5jz hx52
