DSM Jeff
- 558
- 6
- Jun 23, 2003
Connecticut
Went to the parts store today to pick up 2 remanufactured axles (fronts) for my 1990 AWD. Now my 1st question is on the driver side, longer side, there is a the axle that goes into the trans. and then a "carrier bearing" then the cv joint/axle/cv joint then hub splines. Well the new axle doesn't have the axle half with the carrier bearing, there is just the cv joint with splines where something can go in. I'm going to guess i need to reuse that part of my axle? What is the best way of removing this piece. Do i use the carrier as something to pry against, or put the axle in a vise (worried about messing it up)
Next the passenger side, they new one looked different then my old one. Where the axle goes into the tranny, theres the cv casing, the steel part thats green (think most are, saying for visual) the new one had a much larger diameter casing and then the out cv joint looked different. is this normal? i have another one of those on order so we can check.
Please, what do i do with the driver side axle?? and is it normal to have a different looking cv joint casing? sorry for the novel i need to figure this out by tomorrow!!
and if you don't understand i can get a pic up if needed.
