69_luv
- 522
- 9
- Nov 3, 2003
Jacksonville,
Florida
I have a 2g(95), and I have an upgraded(level 10) Automatic. I know that I need to run an aftermarket, or external trans cooler, so two questions. One the stock one on the driver side, will that work in con-junction with another? Second I have two radiatiors, one with trans cooling lines going into the bottom, and another that doesn't. I bought the second of dsmtrader, and found out that although it looks identical it is not. It doesn't have the spot for the transmission cooling lines to go in. How big of a trans cooler should I run? Is it ok that I am not going to use the transcooling circulation on the radiator? Any help would be greatly appreciated.
