transmission blow....parts were flying
InjenTalon96
242
Oct 12, 2003
Plainville, Connecticut
ok heres the deal....i was downshifting off the highway one day from a high speed....(130) 5th to 4th....and sumthing blew out from the tranny....i think the pan from it. well after i heard that noise i put in the clutch and took it out of gear and didnt put it back in gear...the motor was running fine but i got out to look behind the car there were a few pieces on the ground....looking like gears of sum sort....dont really know where the are from though...then there was a piece of the transmission casing that had a bolt in it that look like a drain for the transmission that was also out on the ground. this is what i needed at like 230 in the morning so i put it in first to go home and try to move but the car doents move...but the speed goes up and i hear gears spinning....then i got to second, third, fourth, fifth and the speed just keeps going up....but the car doesnt move anywhere....
i need to know WTF happened
please someone help me....
:talon:
Sounds like you killed your transmission, but that should have been rather obvious. They aren't bulletproof.
