DNA_Cyan
- 42
- Oct 10, 2002
I first posted this question in the General/Newbie forum, but did not receive much advises there.....so here it goes again.
my 3rd gear synchro is going. it grinds from 2->3 and from 4->3.
double clutching only works at certain rpms......if I rev too high in 2nd, and I want to upshift to 3, it grinds even when I double clutch.
similarly, if I am going faster than 50kph in 4th, and I dbl clutch + revmatch down to 3rd, it still grinds.
I have put in GM Synchromesh, but still facing the same problem.
Budget is tight, and i have heard from people that the 90 tranny is not worth rebuilding. Should I just buy a used tranny and replace it? or buy a pre-rebuilt tranny and pop it in?
if the 90 tranny is not much good, which tranny should I look for? which spline? Most trannys on sale comes with the transfer case. Should I get that replaced as well? Remember, budget is extremely tight. I do not think I can afford a pre-rebuilt tranny from a performance tranny shop.
Hope you guys can help me here. Right now, I can't afford to look at the performance side of things. I just want to get the car in good running condition.
Thanx in advance.
Thanx in advance.
