6 bolt swap F up
funguy
125
Sep 29, 2004
Rickshaw,
hey guys,
i'm not sure if there is something wrong. but i can't get my clutch to disenage even when the cylinders and rods are getting full travel. this needs to be fixed asap so i can drive the damn thing
heres what i have
new fresh 2.3l eagle stroker 6 bolt into my 2g awd
competition stage 4 6 puck clutch with their TO bearing
ACT flywheel
pulled the boot off, supposedly my mechanic says the fork is hitting the god damn bellhousing, thats how i BLEW my SS line. I need some answers asap if possible.
I'm dying for a answer please.
If it's hitting the bell housing, then you probably need a new clutch fork and pivot ball, or shim the pivot ball out. Where is the clutch fork sitting when the clutch is not pressed in? It should be tilted towards the drivers side. If it isn't, then replace the fork and ball.
