BOOSTEDPSI1
- Dec 12, 2002
Atlanta,
Georgia
First off the car is my brother's 97 GSX with Clutch Master Stage III clutch. He encounter the problem driving home from work, cruising along about 70mph, 5th gear pops out. Unable to get it back into gear, he is able to smash it into 3rd making it home.
Well here is the dilemma, we cannot get into any gears while the car is on. However, when the car is off we are capable of selecting any particular gear with ease. We did the basic troubleshooting: checking the master/slave, which was both leaking so we replaced both with new OEM parts. Bleed the hell out of the system, still unable to get it into any gears with the car on. We also checked to make sure the lines are not leaking.
Our last option is break the clutch apart to see if the clutch disc is shattered. What other items should I check? Is it even the clutch or is it the transmission?
Thanks in advance.
Thanks in advance.
