91 Tsi Awd Swapped from a/t to m/t
hkyredlineracer
Feb 11, 2003
Hey guys, I recently bought this car after the swap was done. It seems to be a fairly clean job by who did it, but I do have problem. I can getting a tps cel, I have measured both the harness and the sensor itself using info from the dsm cd manual and all checks out fine. Then I read that the tcu used a tps signal as well, so my question is, since the tcu is out of the car could this be throwing a cel? And also I just found out it has an auto ecu in it, (it's not being driven and will be changed as soon as I can get another ecu) Could this be the culprit?
I'm not new to dsms, but this being an auto shell, is the first one I've ever messed with.
