420a Main Seal Leak help !!!
Eclipsemblue
356
2
May 8, 2004
####DSMTUNERS, Maryland
Hey ppl after about 2 months of research (basically screwing around starring at the car) i found out were my oil leak was coming from, the main seal it leaks down the transfer case, since my main seal is busted ass the oil has leaked into my clutch causing it to slip massivly under exceleration which is poo, so i got myself a center force clutch for my 420a eclipse, but i need to know where i can get a main seal at for my car would anyone know ?¿ . Also anyone have directions to drop the transmission chilton doesnt make a manual book :( was wondering if anyone knew some online help, i know what to do its always good though to have a 2nd source to know what your doing so you dont mess up anything. Thanks guys
scale 1-10 how hard do you think it is to install a new clutch
(10 being the hardest)
You can get a main seal for your car at your local mitsubishi dealership. If they can't help you, there are plenty of vendors/sponsors on this forum that can help you out, just give them a call and tell them what you need.
About removing your transmission.
It should be the same as any other fwd car. Look on the vfaq for clutch swap under the driveline section, that should be all you need.
zoogle said:
difficulty: 3
Pain in the ass factor: 8
LOL, ill check wit mitsu tommrow, they will proble want like 80 bucks for it LOL plus 105 Shipping :D
