Phil1320
- 2,256
- 41
- Dec 9, 2002
Rocky Hill,
Connecticut
....I won't make this a long post, but to say today was one of the toughest driving days for me is an understatement.......first, I thought I might have rooked the headgasket, it turned out to be a leak on one of the heater hoses....so that was my loss of coolant.....FIXED this morning and went to the track.
I had multiple passes in the 12.2-12-3 range....mid 111's MPH
Later in the day I was getting into a groove.........and the end result was a [email protected] and the new best for me is: and I can't believe how close and all my friends in the stands apparently reacted as such....
[email protected]
That close! I made a 12.1 pass after and missed third on my last pass...that's it.
So, a step in the right direction...and having the AFC in definitely helped.
My best 60' of the day was 1.67, best 1/8 was [email protected] on the 12.00 run. Can you guys believe it....? I never thought this was going to be easy at all with whats done to the Talon, but, I thought I might come out with 2 or so 11 sec. passes. I will try to get a video of that run up here. Last....boost was 19 or so and it was running well at that level....I never got it up to 21 where I normally run. I think this is in part due to the fact that I have two leaks in the turbo/manifold area. After today, I will keep going, but, if I do keep this car, a turbo upgrade is a must. I will at least repair all leaks and play with suspension and welded diff or viscous for next year early in the spring. But, I am done for the year.....driving back from the track which is about a 100 mile trip, the Talon turned over 79,000 original miles.
SO, I'm still [email protected] a little closer to 11's now! The new best is my best ET and MPH to date.
I tried....so, what do you think?
Later,
Phil1320
[email protected]
Later,
Phil1320
