60 ft times!!
highpsi93tsi
412
Sep 2, 2002
mines a 1.95 even though I still have a leak somewhere, 1/8th mph 70 and ET 9.68 and 1/4 88 mph and ET 15.30.
Car is a 93 AWD with new motor .20 over, open k+n, 2.5" s/s exaust, centerforce stage 3 df clutch...stock turbo and boost on 92 octane. Anyone else running a similar set-up?? i know it should be atleast running 14.30-14.80.
The quarter mile MPH is pretty low. This is a 5-speed car right?
I would say check for leaks first and maybe get a logger to ensure you are getting the proper amount of timing, knock, and an idea of A/F.
Murray
Thanks, i know something isnt right.
It is a stick 14b car, I have no leaks at the pipe clamps/connections but where do I check now? Thanks again.
hey Canadian guy :)
Yea your 60' is fine, could be better, but not bad at all.
But your 1/4 is horrid. Sorry but it is. You have some mods, and should be good for low 14's or so. Especially with a decent 60'
Ask around at the dsm.ca pages, there are some helpful locals near you that could look at your car etc.
do you have a boost gauge? if your only running like 10-11psi then your trap is a little slow, but not a whole lot, maybe 94mph tops for stock boost, if you have the boost up at all, which usually full exhaust does, it should be running mid to high 90's trap
