Cool. Im pretty sure it has a boost leak but im back up north now and have to wait till july 12th to go play with it some more. Im going to have to hack the maf because i was just hitting full boost at 2400hz and i need to clamp the maf by then to use fake maf in dsm link. Boost needs to be stable by 2400hz. I will get it dialed in next trip home. 12 days of nothing better to do.
I had the boost at about 27psi and it was flowing 47-48lbs/min but just didnt feel very good and didnt seem to make much more power. That and the wavy maf signal....reading just over 3000hz.
I feel like it developed a boost leak at the track because the first run of the day it went 96mph @ 23psi and then i couldnt get better than 94 for the rest of the day at the same boost level. It also started idling crappy towards the end of the day and the STFT's were maxed out lean. Still felt fine under power but im sure i was losing some air somewhere. DAMNIT this is bugging me that i cant go sort it out.
