Engine cooling help
SaiyanFury
61
2
Jun 10, 2005
Bell, Florida
Hi I'm down here in Florida on vacation in which I drove my DSM down here. When I got down here my primary rad fan went out so I replaced it with a Mr. Gasket slimline fan that does work. Although I was driving around today and my coolant gauge went over to just under 2/3 when I was driving in the city. The temperature outside was about 75 degrees, and I'm using the fan on the engine side of the radiator. I'm wondering if the factory setting on the fanblade is set for puller or pusher? I'm guessing puller since I assume that's what most street guys would use.
But I could be wrong. The fan WAS cooling the engine as I could see the coolant gauge drop back towards half, but as soon as I started driving again from a stop it heats right back up again. My car is a turbo, and I'm using an EVO III Big 16G turbo on my car. I know turbo engines get hotter than normally aspirated engines, but I don't think that it should get that hot. I should let it be known that I do have AC although I wasn't using it, and I don't have an AC fan where it would normally go yet, as I still have to get another slimline fan in there to accomadate my intercooler ducting.
Does anybody have any pointers or advice they could give me? I'd be most appreciative. I'm just hoping my car doesn't overheat as I have 2000 miles to drive to get back home. Thanks guys!
