Deltatek
- Jul 25, 2003
its driving me nuts. with all the same mods as i has prior to getting a 15% over stock clutch, i know cant get off the line like i could on my stock clutch. going from a 13.8 to a 14.2. and i cant figure out why its cuaseing this. im luanching the car at the same rpms and everything. only it seems to bog a little before it reacts. any suggestions would be great before i go next wensday. thanx
If the new clutch is a little stronger than your OEM clutch, maybe launching at a slight higher RPM range might help compensate. Also, was this just a 1 time thing, or have you gone to the track numerous times with the new clutch and noticed the slower ET. (what im trying to get to is maybe the weather had a lil bit to do with it, or something of that nature. Not enough to drop .5 off your et, but just something to take into consideration)
