10-08-2003, 02:17 PM
#1 (permalink)
Proven Member
Car: 1999 GMC Yukon
Region: Midwest
Custom making/Fab. of Exhaust Manifold/ Header?
Im really thinking of custom fabricating me a exhuast manifold/header. Im not going to cheap out on a PaceCraper. Im a expert in metal working. I already had to custom fabricate a header on a CBR 600 Motor that was custom mounted on a go-cart frame that me and some friends built. I can get the metal from Metals class at school. I can make my self a jig to weld it together. I just want to know what type of metal tubing is the best? Any info is appreciated. If this isn't "tech" enough then lock it.
____________________________
Brandon
Offline
10-08-2003, 06:34 PM
#2 (permalink)
Proven Member
i would use 304L stainless if i were you, i am also a metal fabricator and all we use at our shop on headers is 304 stainless with a .065 wall thickness, and it will never rust and can be polished to a mirror shine although it will become a goldish color when its heated by your exhaust,
321 stainless is better for high heat applications but we use 304 and have no problems with cracking on our turbo cars, plus 304 is about 1/2 the price of 321.
Offline
10-09-2003, 01:49 PM
#3 (permalink)
Proven Member
Car: 1999 GMC Yukon
Region: Midwest
Thanks. Ill ask my metals teacher to see if I can get it. The thing is that our Mandral Pipe Bender at school is broken. So Im going have to find out another way of bending it if we dont get it fixed.
Brandon
Offline
10-09-2003, 04:20 PM
#4 (permalink)
Proven Member
Region: Rocky Mountain
you could always buy the pre bent stuff. also check out sdsefi.com
here is the article http://sdsefi.com/techheader.htm
Josh
Offline
10-09-2003, 08:04 PM
#5 (permalink)
Proven Member
Quote:
You have a mandrel pipe bender at your school......!!!! :eek:
Mike
[img]http://www.dsmtuners.com/forums/avatar.php?userid=16402&dateline=1067447598[/img]
Offline
10-10-2003, 01:25 AM
#6 (permalink)
Moderator
It likely broke when someone tried to bend stainless tubing with it.
Offline
10-10-2003, 02:48 PM
#7 (permalink)
Proven Member
Car: 1999 GMC Yukon
Region: Midwest
Yeah we have a mandrel pipe bender at our school. Recently our Vo-Tech classes got a huge ass grant. Im talking $50,000 grant money. The Building Trades class got 35K worth of all Dewalt tools, I mean everything you can think of we have it. Metals got the pipe bender and 4 brand new Mig and Tig welders. Woods class got a new planner, and 2 new table saws.
Brandon
Offline
10-11-2003, 02:05 PM
#8 (permalink)
Proven Member
As a "project" you should make some exhausts.
Offline
10-30-2003, 02:30 PM
#9 (permalink)
Banned
go make 1000 bends and sell them to assholes on ebay.
Offline
10-30-2003, 07:06 PM
#10 (permalink)
Proven Member
Car: Porsche 944 Turbo
Quote:
I can bend stainless without much problem.... not mandrel, but don't see why a mandrel bender would have trouble doing it either.
Rogue
Offline
11-04-2003, 08:05 AM
#11 (permalink)
Proven Member
Mandrel bender shouldn't break bending stainless, unless....
The pipe slips during the bending process, then wrinkles, then the mandrel starts to withdraw, and it can't because the pipe is wrinkled, so the mandrel balls snap and you are left hating life. Get serrated grip dies (not carbide), watch the pipe for slippage, and save yourself a $3000 die fix (unless its 3", then it'll be $6000).
Are you sure its a mandrel bender at school?? I'm just saying for the grant money you guys received you couldn't really buy tools, a mandrel bender and dies (just the mandrel dies range from $1500 to $6000 and UP PER SET, a good machine is about $40000-$75000). You need a special die for every OD tube, as well as the ID since the mandrel rides inside the tube. You more than likely have a hydraulic bender (which is a crush bender). But, if you do have a mandrel bender and its broken let me know (snapped mandrel, wiper die, etc), I may have the parts you need to fix it.
Or, I'd be more than happy to sell the school my DB2060K with 2.5" and 3" dies for the bargain basement price of $32000:-)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
