STARION
- 193
- May 30, 2002
Nova,
hello all,
This is just me pondering about the shape of the metal and its strength. I fabricate a good number of items on my car and am thinking about a roll cage. Now, quite obviously, roll cages available for sale are produced from circular metal tubing (most commonly chromoly steel I believe). Generally, when I am fabricating a part for my car and the situation calls for tubing, I tend to favor the use of square tubing. It began, because I was a lousy welder and the flat sides made things simpler to run a bead on, but now I use it because I believe it to be stronger. However, I do not have any proof to claim this as factual. Anyhow, things brings up the question, why not buld a roll cage of square tubing as opposed to circular?
Let's say you have 2" OD circular tubing and 2" OD (diagonal) square tubing, keeping things constant, we'll say they are identical thicknesss (gauge) and identical type (cromo steel in this case), and their weights would be very similar. Now I know everyone is thinking that you use circular because it can be bent, curved, etc... Sure, thats a major concern is mass production I suppose, but if I were building one from square, I would just angle-cut it and re-weld it (keep in mind that a good, well executed weld is as strong, if not STRONGER than the metal itself) heck, you see some japanese tuning firms still using this method on their prize cars if you think I'm crazy.
Now, onto the question, with all things as listed above, and I go ahead and build a roll cage from square over circular, will the car be more structurally rigid than if I had built a cage with circular (this, assuming that I build the 2 cages with the exact came points of contact with the car, frame, same angles, etc..). I believe this field of study is called statics? I'm sure there must be some mathematical formula for this, or somebody who has done tensile strength testing and all that business.
I was looking for some kind of existing evidence to try and find my answer, but there was always a point, counterpoint. I would decide that square was stronger, because I would look at how darn near every production car I saw always had a square/rectangular frame....then I would look at just about every "tube chassis" car I had ever seen and realized that they all used circular, each of these respective parties must be using the most rigid form available. I could go on and on with examples.
anyone?
anyone?
