XTurboSpYderX
- 805
- 4
- Sep 19, 2002
Anchorage,
Alaska
Is anyone running the "stroker" crank from the 4G64 in a 7-bolt 4G63 with HKS 272 cams and 1mm oversized valves? I am looking at going this direction but I am wondering if there will be problems with the piston/valve clearance. I am looking at going .020 over Wiesco pistons on Eagle rods w/a knife-edged 4G64 crank on the bottom of a 1G 7-bolt. the head will be worked with 272s pushing 1mm oversized nitrate coated valves on both sides. is there anyone that has this (or very similar) setup? I am open to any thoughts or insites on this setup, as it sits I have just stripped the block bare. I haven't even taken it to the machine shop yet, so I have time to think about exactally what I am going to do.
Thanks in advance -
Thanks in advance -
