Need a Second oppinion on my timing
blackhawkgsx
250
2
Mar 6, 2010
Miami, Florida
Hey guys i just did my timing on my gst today and just wanted a second opinion on the marks lining up THanks in advanced guys!
Looks dead on to me. I didn't check your profile. . . do you have balance shafts? If you have balance shafts rotate the crank completely 6 times and make sure they all line up. If you don't have balance shafts. . . you only have to worry about the cams and crank.
Tension set correct? pulleys changed? It would suck if you did all that and have the tensioner fail, or not correctly, and pulleys could do out too, I had that happen, when i only changed the belt, i live and learn.
At first I thought it was off at the crank, then checked your profile and noticed that you did a 6-bolt swap.
