deflator
- 535
- 4
- Jan 5, 2007
livonia,
Michigan
I searched, but I still have unanswered questions. I'm putting my rebuilt 7-bolt head with FP2 cams on my built 6-bolt block.
I know I need to bore out the holes for the headstuds. What I can't figure out is what timing components I can re-use, and what I need to purchase.
Will I be able to use the pulleys, tensioner, and belt on the new block? They were all almost new on my 7 bolt.
And since I am using the 2g cam gears, I can re-use the same timing belt right?
And timing covers? Will the lower 2 be 6-bolt and the upper 7?
And the crank pulley is the same for all years right?
On another note, how do you guys feel about buying used ARP headstuds? Too much of a risk to save $50?
Sorry for all the questions, I'm trying to figure out what to sell and what to keep.
