talonalex92
- 1,792
- 10
- Apr 20, 2006
Akron/330,
Ohio
To make a long story short, I bought new cams and installed them about 3/4 weeks ago. Car was running amazingly. I got this horrid god awful noise. I trailered my car to my moms garage, to work on it out of weather, to find that its from the top end. Took timing covers and accessory belts off, still noise. Pulled intake mani off, nothing broken back there, or vibrating or hitting the block. Pulled the valve cover and started car. LOUD noise. Hm. Upon further inspection, I notice my cams are...offset? They are wearing in the center of the lobes like normal on the 2 cylinders closest to the timing side, the 2 towards the passenger side, are riding on the far far left of the lobe, the rocker is parallel with the lobe. Its vary off center, both cams are the same way. In further inspection, my intake cam is hitting and slowly grinding away at the number 5 cap. Im working with the vendor, nameless, and im wondering if this ruined my head. The cam journal seems fine on that section. No scoring, no marks. The cap is vary rough, small lined gouges through the length of it. Im assuming the metal shaved off the cap, slid in there. Im also assuming the caps are bad. Any one have insight to this happening to them with BC cams? Will my head be ok? Im assuming the caps are shot. Ill be posting pictures later, when im off work but that's as specific as I can get. Im hoping my vendor will take care of it all, at fault of BC. Anyone have any similar situations with the cams, head or a defective item ruining something? Did it get taken care of? There is no install error, they go in one way, one way only. Its physically impossible to install them wrong and have the car run. Also, its physically impossible to get the caps wrong. God. Someone tell me something. Gr.
I would be extremely happy if i got some free spring/retainers, i wouldnt mind at all if the cams did that my head, to me its a simple job.
