Novacaine
- Sep 26, 2002
First off i have 2 dsm's awd's one is stock engine with bolt on's
buschur fmic
550's vpc/gcc
comso pump
3" exhaust
20g EVO III manifold
Hks standard gate 15lb spring
This setup is very streetable and my daily driver and now to my problem...
1992 tsi awd
Fully built bottem end
arias pistons 8.5 to 1 comp
eagle H beam rods
knife crank
balance shafts removed and balanced rotating assembly
Mild port and polish head
Crower 64414 cams
titanium retainers
Crower springs
Arp bolts throughout
ACT 2900 6 puck
Buschur Fmic
3" exhaust
Turbonetics exhaust manifold w/deltagate 7lb spring
Bushur BR57 turbo 60-1 .63 a/r
vpc/gcc (old style gcc) 660 chip in vpc
680cc inj
BR/SX Fuel Pressure Regulator Kit
cosmo pump
Gauges& instruments
Pocketlogger
Egt
Boost
A/f
ECU mods
TMO 8500 rev limit, no fc
This car is my nemesis..
I have had to reduce fuel pressure to 32psi just to get the car to idle and idle is set to about 1300-1500 rpm due to cams
funny thing is setup is having knock problems even tho the fuel mix is way rich the car is currently ran on pump gas (yea i know just gettin set up first then over to race gas heck im only running 7 psi ya know
Knock counts rise almost imediatly when accelerator is pushed counts reach about 40 anything above 4500rpm and yes that's at 7 psi !
the vpc and gcc are both max reduction at idle and im still way rich even with the fuel press at 32. Is it possible to have knock in a rich state? Egt's are around 1200 WOT till about 4500 then they start rising i let off around 1425F and o2's are .94. I just dont get how the car is knocking so severe. The car is for sure in time and head was only shaved .010 just to clean it up. Any ideas would be greatly appreciated.
Thx
buschur fmic
550's vpc/gcc
comso pump
3" exhaust
1992 tsi awd
eagle H beam rods
knife crank
Crower 64414 cams
titanium retainers
Crower springs
ACT 2900 6 puck
Buschur Fmic
3" exhaust
680cc inj
cosmo pump
Gauges& instruments
Pocketlogger
Egt
Boost
A/f
ECU mods
Thx
