dsmusmc
- 422
- 1
- Oct 1, 2007
Alliance,
Ohio
Found a hell of a deal on another turbo and swapping out to a T4 so no need for this just to sit around. Had it on the car for 300 miles for a tune then pulled the engine last winter and the swap has not happened. Turbo comes with a divided T3 .76a/r housing thats been coated and will include -4 feed fitting and -10 return fitting. On a stock 2.0 with 272's I saw 20psi by 4200RPM. Will include JMFab o2 housing thats been coated as well. Over $1,700 worth.
Turbocharger Name - S362
Compressor Wheel Inducer - 62mm
Compressor Wheel Exducer - 80.6mm
Compressor Wheel Trim - 54
Turbine Wheel Inducer - 76.3mm
Turbine Wheel Exducer - 67.6mm
Turbine Wheel Trim - 79
Turbine Option - Outlet - 6-bolt
Turbine Option - Inlet - divided T3
Turbine Option - A/R - 0.76
Horsepower Rating - 350-680
$1,000 shipped
$1,000 shipped
