machine work for the 95 piston with big rods
jokerswild8282
35
Nov 9, 2003
i was wondering if anyone who has done the 95-99 pistons with the 1g rods if they could tell me what needs to be machined and if the turbo rods are the same as the non turbo rods from the 1g a pic of what needs to be mochined would be great since no one around here has ever done them it seems that i am a lone wolf in a bunch of honda ####ys
To install a set of 2g pistons on the 6-bolt 1G rods one must.
A: Narrow the pin end .100, (the distance from one side of the hole to the other)
B: Increace the diameter of the wrist pin hole by about 1mm. Be sure not to remove to much here, as the interfearence fit between the wrist pin and the rod must be maintained, the interfearence fit should be .0008-.0009. Since this is a interfearence fit or press fit if you will, the wrist pin hole diameter in the rods must end up .0008 to .0009 smaller than the diameter of the wrist pin.
    • 92AWDHX40
    • eclipsemf
