MNGSX
- 2,533
- 25
- Mar 30, 2003
Bloomington,
Minnesota
Anyone who has ACTUALLY has one of these or another brand of turbo with the same combination of housings and wheels (FP, AGP etc) please chime in. Maybe with your initial experence with it as well as what it was like once you got it tuned and used to it.
) the oil pressure on the pump side of the check valve is below the accumulator side. So the accumulator pressurizes the other side of the system and provides oil untill it's discharged or the pressure from the pump increases. When you go from say wot to idle it will discharge untill the accumulator pressure meets the system input.
