Groomz
- 1,532
- 1
- Oct 29, 2002
Texas,
Texas
I've been thinking about how 4G63T engines have hydraulic lifters for the camshaft followers. I understand how a Chevy or Ford lifter works, and would assume that they operate on the same basic principles. I know that there is the rocker arm that has a follower for the camshaft ( 4G63T ) which is attached at one end to the valve and the other to the hydraulic lifter. What I don't understand is its purpose. I would assume the basic geometry of a rocker would have one point fixed and have the camshaft lobe pass over it, exchanging that motion to the valve and valve spring. My question is that do the hydraulic lifters change height based on oil pressure or are their heights fixed? If oil pressure is not present, do the hydraulic lifters shrink back into the head and not allow the camshaft to act on the rocker?
I hope this makes sense to someone. Obviously the design works and is capable of very high RPMs, but I would still like to understand this part of my engine. I have had very bad phantom knock and this is why I have been thinking about the lifters. When replacing the lifters with 3G ones that have the larger oil passages, are the only benefits better oiling and reduced noise? I only ask this because I don't understand how the lifters work. Thanks for reading this far if you have, and any thoughts you have are most appreciated.
Merry Christmas!
Merry Christmas!
