EGT gauge
Newlogics
1,106
18
Jul 23, 2002
San Leandro, California
Hi guys,
I've just gone over EGT gauge installation on VFAQ 'cause I'll be putting one in these weekends, but here's my concern:
They suggest using a clamp to keep the probe in its place, but wouldn't that be insufficiently sealed and contribute to pressure loss ?
Or is it not signifficant ?
Is there a better way to put the probe in the manifold ?
Are there any probes with screw-in plugs to screw into a threaded Mnifold hole? Welding is a problematic option for me, since my car is a daily commuter and I can't really leave it in the shop.
Mine is screwed in with a little JB weld on the threads for assurance. No exhaust leaks and works perfect.
jeff
Find your gauge and buy a probe from TRE, $38 and fast acting. Drill a hole, tap it, and screw your probe in and you're done.
My Autometer EGT came with a clamp, or screw in option. I went with the clamp since I don't have a tap kit. It came with a ceramic washer and I test fitted the clamp before I drilled the hole to get a better idea of where to get optimum fit with an accurate reading. Just turned that clamp till it was extremly tight- no leaks, reads what I thought it would.
Justin
