Mirageman
- Feb 3, 2003
I have a 4g63 Mirage that is modded to about 315 WHP using a small 16G. I have 2 fully ported T. housings for this 16G and wondered if anyone has ever lathed off metal in the turbine wheel hole to give the same affect as clipping the wheel. Since I have a shop lathe this would be far cheaper than clipping the wheel and the cartridge rebuild needed when taking the shaft out to be clipped. I should be able to accomplish the same affect with this extra housing. I have already had the housings in a lathe to taper the hole at an angle coming away from the wheel to match the O2 gasket. I am trying to see how far I can go with a 16G.
Any thoughts on this?
