jb talons
- 176
- 1
- Sep 19, 2002
Latrobe,
Pennsylvania
I just installed my mbc - standard Turbo XS. I installed it with the hose coming off the compressor housing going into the mbc and the outlet going to the waste gate.
I did a couple of wot pulls through 2nd and 3rd gears and got the mbc adjusted so that it peaks at 15 psi.
My question is:
Is it normal for the boost to fall off at higher rpm's or should it stay at the max setting? What happens is, I get the 15 psi at about 3k, then it starts to fall to about 10 to 12 psi at 5 to 5.5K.
I was under the impression that it should go to the max setting and hold there.
Anybody got any input that can help me out.
Thanks,
JB
My question is:
Thanks,
JB
