mustg5
- 278
- Nov 3, 2003
what is the difference between a A/F controller and a Data Logger?? Do i need a data logger if i have a A/F controller?? Thanks
Get the Datalogger first, then the AF Controller, use them together to make power.Originally posted by GTM
Hi all:
Front panel / keypad / printer etc.
This can get moved to a new thread, PM or email.
Cheers,
GTM
Hi all:
I need some basic help with a data logger. I would like to know if the software is compatable between the different loggers? And/or if the retrieved data uses a common data format which can be imported into Excel spreadsheets or Graph makers?
Cheers,
GTM
Originally posted by steve
or a Palm PDA. The datalogging software supports either OBD 1 or OBD 2 communications protocols to talk to the ECU depending on which year cars.
The log file formats tend to be specific to the datalogger software but many can export csv datafiles so you can use excel or other programs to play with the data.
PS I want to see you mount that Fluke in your dash.![]()
OBD 1 is found on 1G DSM's and most 2G's run OBD 2 in their ECU's.
The cheapest OBD 1 solution is a PalmOS device with MMCd software and a homemade cable to convert the +12v ECU signalling to RS232. I have schematics if you need them.
Steve
Not sure and not sure how standard the spec really is. OBD1 seems to require more car specific details in the software than OBD 2 which started showing up around '95. The '94 and earlier DSM's used OBD 1, so at least '89 for it.Originally posted by GTM
Any idea when OBD 1 was adopted as a standard? Is OBD 2 backwards compatable?
