What triggers code 31 (knock sensor)?
Diz
54
Nov 18, 2002
Fillmore, California
What is the logic that triggers this code? Zero signal from the sensor? Excessive voltage? Why would it trigger with the sensor disconnected? I'm assuming the sensor generates a small voltage signal during knock and none under normal conditions...
if you have the knock sensor unplugged you should get a default value of 9 counts of knock while driving. if the knock sensor in plugged in, but not screwed into the block i believe you get the code you are talking about. the knock sensor is electrically grounded though its physical contact with the block when it is screwed in.
