What Else Would I Need To Install My 38mm External Wastegate
BOOSTED4LIFE90
105
Aug 30, 2003
Anaheim, California
hey fellas well i recently purchased a 3'' o2 housing with an external wastegate flange welded on the o2 pipe from RNR,the flange is for a tail 38mm external wastegate and i was wondering if any of u fellas can help with the installation,i need to install the o2 housing and the external wastegate,i also wanted to know what else would i need to install the wastegate as far as hoses and all?because ive seen pictures of external wastegates and theres a hose running from the wastegate to the intake or somewhere around there,does anybody know what im talking about?i really need your help guys,you guys have not let me down yet.allright fellas your help would really be appriciated,if anybodys got any instructions on the installations it would be appriciated,i mean i really need someone to walk me through.thanks fellas i need as much help as i can get.laters!
Depends on your setup. If your not running a boost controller or just a manual then take the vacuum off your original wastegate and put it onto the side of your Tial wastgate and leave the top open. (top and side together is for Electronic Boost control)
Its a wastegate like any wastegate. You connect it to the end of a boost controller. You might want to get a dump tube so you dont shoot exhaust gas into your engine bay. I hear that stuff gets quite hot.
