Spdrcr7882
- 105
- Jan 6, 2003
Danbury,
Connecticut
I recently had to put a new head and timing belt on my car, and when putting the timing belt on, i could not line up the cam gears witht the crank pulley perfectly. It seemed like i could have either had the mark on the crank pulley alittle ahead or alittle behind the mark on the block. I am not positive which one i chose, but my car doesn't seem to be running bad. THe thing is that i have a shitty gasket between my o2 and my exhaust so i got a real bad leak, so i have not gotten on it much since i put the car back together. If my timing belt was off a tooth on the crank pulley how much of a differnce would this make? Will i notice a big difference?, if there a way to check my timing without taking my timing belt cover off?
thanx
Justin
thanx
Justin
