johnnytsi
- 176
- 10
- Aug 20, 2002
Everett,
Washington
I have finally decided that I have outgrown my BIG16G and want to go bigger, however I really like the quick spool times of my small turbo.
I've done a lot of research on turbos over the last few days.
From what I've read the turbonetics ceramic ball bearing turbo would make a KILLER street turbo, the ball bearing center section will let the bigger turbo spool much quicker like a small turbo. The best of both worlds!
I'm leaning toward buying a t3/t4 60trim with the ball bearing center housing. And buying a filtered oil feed line setup.
My only concern is the daily driver part! There seems to be some mixed opinions (no real facts) on how long these turbo's will last? If you are running one of these, your impressions would be appreciated.
Thanks,
John-
Thanks,
John-
its a t3/t4 setup but it should still make some serious power. check out
