Car wont idle
RaysTsi
323
Nov 4, 2002
Charlotte, North Carolina
I recently did a 6 bolt swap with a 1g head, 2g intake mani, 2g tb, and now my car wont idle at all. I replaced the ISC motor with a good one and my car still does not idle at all.:mad: What else could be wrong?
It sometimes takes time for the ECU to get the idle right. But would definitely check the intake for leaks.. then check/adjust the base timing (s/b 5deg BTDC) and then the base ide (s/b 500RPM).
Good luck!
however the idle should be a little higher than 500rpm... shoot for roughly 750-900 (as long as it doesnt start searching) May I ask why you are still using the 2G intake equipment?
Okay I checked the intake psss, vacuum hose was comletely loose, I clamped it down. Checked the BISS it was all the way down, I screwed it out 3-4 turns. My car still doesn't idle, when I start it I have to give it a lil gas and if I give it a little gas and then let off the gas peddle the rpm will shoot upto 1500 and then settle back down at 0. WTF?
