AFC Install
snipe99999
301
May 13, 2002
I am going to be installing the AFC tomorrow just need a few things answered.
1. This is the correct diagram to use here
2. The white and yellow wires are the only 2 that will not be used
3. After cutting the air flow signal wire in half I connect the pink to the ecu side and the orange to the other side and leave it cut. I do not reconnect this wire correct?
4. After the install the only thing that I have to do is turn on the car and initialize the AFC and it will be set to stock settings? Nothing else required here?
I will be installing the turbo and injectors in a week but just wanted to get the AFC working before I did. I have a good backround in wiring car audio but not this stuff that is why I am asking so many questions. Please if I am wrong let me know or if there is something that I am missing let me know. For now I just want to get it hooked up but leave it stock.
While you are in there, do the blue wire mod. Connect the blue wire that is not being used and splice it to the o2 wire of the ECU.
But yeah, initialize it, then start the Car. Arrow: up, 4 cylndr, Throttle type: Karman, Throttle Position (High: 80, Low: 30).
Do all of the preliminary set ups before you start the car. Anything below 30% throttle will consume less gas at lower RPM's and anything at 80% or above will consume alot of gas, depending on the Fuel ratio you dialed in (+ -).
