fuel system for 60trim
Civic Killer
Feb 14, 2002
ok im getting the pte 60trim for my 91 gsx and want to know if this fuel system will be enough..
720's 255walbro afpr. haltech ems
im shooting for 400whp any comments will help thanks.
How bout an intercooler and a freer flowing exhaust for starters. That large a trim will have some high demands. I would make a plan as to how much air you will be flowing with this high trim and choose your injector size accordingly. Cuz with a stock engine upgraded turbo bigger injectors, and an EMS system, there is soo much else to be considered like flow through your stock intake and boost pressures through your nylon rubber intercooler tubing, head gaskets, headbolts, bottom end. There is much more to it than just what you got on that list. Also running such high injectors will just make you buy more gas frequently even with the EMS as there is minimum cycle rate for all injectors which may make it rich at idle. Just a thought...
as far as other mods i have
vpe fmic
2600act
turbo xs rfl bov
3in exhaust turbo
metal head gasket
studs are on the way.
I thought the 2600 was too much for GSTs? have you had any problems with that? a ported or aftermarket exhaust mani and 02 housing will help. let me know how that goes....after my 2nd turbo swap and fmic with tuning, I'm hoping to be there as well.
those are my mods on the 91 gsx. but i also have the 2600 on the gst i like it alot i havent had any problems with it at all. yeah i was thinking of just sticking with the 2g or evo ported but knowing me i'll end up with a aftermarket one.
