Which injectors to run with PTE 50 trim?
Clipse
509
Sep 25, 2002
Renton, Washington
Ok... So, I know I want the PTE 50 trim turbo. I'm just not sure what size injectors I should run with it. I have been told 650cc and 550cc (ball/disc style). I would like to go with 550s because they're about $100 cheaper, but I won't sacrafice performance for $. So tell me, wouldn't I be killing the 550s with that big of a turbo? Thanks in advance,
With that turbo you should definitely go 660's. I'm sure you would max out the duty cycle on 550's. 550's are perfect for FP Big28's, 16g's, and big 16g's, but not for a 50 trim.
660's are a good choice. If you have a stand alone and you are buying good high speed injectors with a good spray pattern and 720's cost the same ? Might as well since it wont hurt nothing.
I had 550cc with my 50trim and I maxed them. After being in denial for about a month I finally broke down and bought 650cc. Jee wouldn't you know it, I have 22deg of Timing at WOT now.. Who woulda thought...
