Exhaust Manifold Question
dbritt
178
Jun 9, 2003
Clemson, South Carolina
You Will be fine. The collector will be much larger than you stock 14b. This is not really a problem but you should port the shit out of your exhaust housing if you want to make good use of the manifold. The evo manifold has much larger runners and collector, so it is overall a great manifold, but with a stock unported turbo you will definately not be using it to its full potential. Hope that helped you out.
