rc90gsx
- Sep 9, 2002
rock hill,
South Carolina
im getting major overboost/boost creep using my profec b and tial 35mm wastegate. the low setting will start out a a rock solid 10 psi but will then jump all the way past 20-22 psi. the hi will do the same except it starts out at 15 psi. i have the side nipple on the WG t'd into the bov line and the solenoid IN line is coming from the nipple on the compressor housing of my turbo. the line for the control unit is t'd with the fpr/boost gauge. i've tried the gain knob in both directions but it doesn't seem to help. ive also changed the dipswitch settings from normal external wastegate setting to the overboost external wastegate setting and it did nothing. any help would be appreciated, thanks
