1992 Eclispe 2.0 N/t Need Some Input
EclipseRydazz
169
Apr 26, 2002
Barrington, Illinois
Hey what's going on guys?
I am not knew @ this but here is what i have done so far.
Pace Setter Header
2 1/2 Cat Back System
Injen Intake (Soon to be a custom cold air)
Cut out Silencer
Everything else is stock.
And still running mid to low 17's on 93Oct./and high 16's on 110Oct.
Is there anyother things that you n/t owners or T owners know of what i could do to improve my car a little bit more?
Do you have a downpipe? You could try some weight reduction as well. Are you automatic or manual? You could also resort to nitrous. I wonder how well would a set of HKS cams work on a NT motor??????
damn back when I had my nt I ran low 15's all day long with not much more than you (clutch, 5spd turbo cams,alot of weight reduction) I suggest you check your compression thats what makes an all motor car n/t rings are weak also what where your 60 ft times
