Complete engine rebuild kit
Are you saying this kit can handle this power, or will actually give it to you.? I was thinking of getting this kit also.
any new info on this post?
im also looking at this kit but worried pistons are not strong enough(compared to satans pistons)
do you know what head gasket is used on the kit..the organic or the aluminum?
thanks
I'm sure the HG is organic. And if you buy the turbo kit, comp ratio will be stock. I don't know why you guys think otherwise. But if you have questions, call them up and ask.
So I also want to do an engine rebuild I was also looking at this kit do you think it will be good fro my 98 gsx.
If i'm not mistaken, a 4g63 can handle around 400hp without changing the internals, but I wouldn't get higher compression pistons for a turbo. Much higher chance of detonation
not to jack but what else is missing from this kit to completely redo the engine? rods...i know it doesn't have cams and stuff, im referring to the bottom end, because this is what i need rebuilt
This is a STOCK REBUILD kit. It includes all the gaskets, bearing, new pistons, rings, o-rings. The rods aren't included.
Adriano
