rewire more boost?
my95tsi
926
Dec 6, 2002
Chicago, Illinois
If i rewire my stock fuel pump will i be able to run alittle more boost to like 17psi on my t25? I heard from someone that it is possible to do this but i wanted other opinions.
i would think the advantage to rewiring your fuel pump for a T-25 isn't so much you can run higher than 15psi, but that you can run 15psi more safely than before
I had the same question, but for the 14b...
If you rewire the fuel pump can you turn up the boost?
17psi sound about right?
from experience dont push it unless you have money for a new turbo. my T25 just died same way at a BADDDDDDDDDD time. money wise
