Next mods?
Jarg-gst
Apr 29, 2002
Hey guys, I need help on deciding what mods to get next on my '90 gsx. Car has the following mods:
'95 Block with Teflon coated pistons
'94 Head with mild port job
Balance Shafts removed
550cc Injectors
HKS VPC
20G Turbo ported and clipped 10 degrees.
Hilman manual boost controler
'95 ported exhaust manifold
3in turbo-back exhaust
HKS Wastegate w/ dumptube
Front-mount Spearco intercooler
7lb Fidanza aluminum flywheel
2600lb ACT clutch
Unorthodox Racing underdriven crank pulley
16" Konig Villan Rims
Cross-Drilled and slotted Rotors
A/F and boost gauge
The car ran a 12.4 @ 108 first time at the track. I'm looking to get into the 11's. Any suggestions? Thanks.
I would say go with cams. I cannot recommend a specific type as I have not gone that far yet. Judging from your list that looks to be a very good option.
What are you doing for tuning? If you do not have something like DSMlink or AEM EMS then I would recommend that first to get the most out of your current setup. After rereading your post I would say focus on engine mangement before cams.
Since you have a VPC no need for a stanalone. But cams HKS 264/272 will but put you into the 11's. Mine go on next saturday :D
Later,
